It is currently Sun Sep 05, 2010 1:07 am
Post new topic Reply to topic  [ 11 posts ]
7020 aluminium box section
Author Message
Post 7020 aluminium box section
Anyone know who sells it at a reasonable cost for small lengths, Derbyshire area.
Cheers
Wed Jul 21, 2010 7:48 pm
Profile
Post Re: 7020 aluminium box section
wouldn't have thought 7020 would have been readily available in small portions ..... and it ain't usually cheap neither
richard austin have a place in leeds
Wed Jul 21, 2010 11:36 pm
Profile
Online
6082-T6 is virtually as strong, MUCH cheaper, and much more weldable than 7020.
My Hub Centre Steered monstrosity is pretty much exclusively made from 6082-T6...
Cheers, Mark.
Thu Jul 22, 2010 8:28 pm
Profile WWW
Thanks, I'll look into T6 properties as well
Tue Jul 27, 2010 8:38 pm
Profile
i make everything from 6082 t6
i looked at 7020 but for the strength diff verses price it weren't worth it
Tue Jul 27, 2010 10:53 pm
Profile
It's not so much the strength difference in hardened state. I want to weld it onto a swinger for a Magnum 1 top loop / shock mount and don't want it cracking where welded.
Sat Jul 31, 2010 9:01 am
Profile
Immoral compass
User avatar
specifying T anything on a material spec to be welded is pointless, as the welding process destroys the tempering in that local area. So unless your getting it post weld normalized and re-tempered its best not to need the temper part of the material spec on parts with a weld on them...
_________________
The solutions all are simple — after you have arrived at them. But they’re simple only when you know already what they are.
Sun Aug 01, 2010 7:33 pm
Profile ICQ WWW
isn't 7020 only weldable to 7020 , i use 6082 for slots and weld them onto stock arms
Sun Aug 01, 2010 10:58 pm
Profile
7020 to 7020 - don't know, I have a Honda Big One arm to cut about and play with, probably end up being cashed in for scrap if I'm being honest, but good to practise my Tig on :P
Mon Aug 02, 2010 6:41 pm
Profile
Immoral compass
User avatar
well before you do, cut it up and practice on it, with a slice of it cut out to use as a filler rod!
That way your guarentee'd to be welding the same stuff together with the correct filler rod.
Ive ran out of exotic rods a few times and just used a offcut in a emergency...
_________________
Tue Aug 03, 2010 12:28 am
Profile ICQ WWW
Online
I did that very same thing with some 2" bore Grade 2 titanium tube I was welding...
Sun Aug 08, 2010 12:07 pm
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © phpBB Group.
Designed by Vjacheslav Trushkin for Free Forum/DivisionCore.
